Whirlpool AWG 329 washer dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool AWG 329 washer dryer
  • #8662
    bassman
    Can anyone help? I think this machine is a Smeg it is a fully intergrated machine when switched on it does not do anything.
    The door locks ok I have tried bridging the door lock connections to eliminate interlock, I can hear a couple of faint clicks as if the relays are working on the PCB but nothing happens I have checked pump for continuity also the motor is ok.
    Has anyone seen one of these or got a wiring diagram? Please.
    Thanks Bassman.
    #129861
    Re: Whirlpool AWG 329 washer dryer
    BM,
    It’ll almost certainly be a module fault. Door lock function is through the timer direct, everything else is via the digiboard. If there is a component or function fault the timer will advance through the programme to the “spanner” position and tell you there is a fault.
    It is a SMEG in a skirt, module from Whirlpool is 4812 282 18679 @ £72.61 list.
    Cheers,
    Dave_Conway
    A couple of files on the way bassman, the reproduction isn’t great though I’m afraid.
    Very likely the module though as Chris says.
    #129863
    bassman
    Thanks Lads I thought it may the module But needed confirmation.
    Bassman
    #129864
    bassman
    I replaced Module machine working fine now .
