Whirlpool AWG329
  • #4827
    Ally
    When I set this machine to spin on No7, It empties fine. Then it jumps to a 500 spin for 10 seconds approx, then stops turning. The pump continues running for the rest of the spin cycle? I suspect the module but I am not a 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure.
    #105514
    Dave_Conway
    Ally I had one of these with a similar problem a few years ago, IIRC they are made by Brandt. I replaced the module (not far short of £80 😯 )
    which made no difference at all.
    It turned out that a small restriction in the waste was causing a drain ‘time out’ error. 😳
    The blockage was not obvious as the machine seemed to drain all of the water ok, fairly quickly.
    May be worth a check 1st, or possibly the door lock, it looks on the diagram to have a double switch arrangement.
    HTH
    #105515
    reply
    could easily be the module at fault,we have changed several for this fault on slower spin speed prorammes
    Part number 481228218679
    Regards Ted 8)
    #105516
    DentedPorsche
    Re: Whirlpool AWG329
    If it’s not a washer dryer, take out the door interlock. If there is a microswitch fitted to it, bypass the microswitch and try the machine.
    Sorry, although I work on Whirlpool machines I get lost with their model numbers. Too may different models for my liking.
    Brian
    #105517
    PaulG
    The particular machine is crap. I have had the very same problem and had to get w’pool to replace it after throwing part after part at it, they are a nightmare to work on too. We are talking about the intergrated one here, right?
