Whirlpool AWG338
  • #64745
    johnnyj
    Was called to a timeshare complex i do work for they had a Whirlpool washer dryer blowing fuses, i meggered and could find no fault, it works with the door locked light comming on but doesnt lock the door i tried another door lock thinking this may have caused the fault but still not cured, does anybody have any idea what could be causing this, i know it is a Servis made machine and was thinking that it may be the module or timer which is causing this fault cheers JJ
    #357956
    johnmac11
    Re: Whirlpool AWG338
    I have not saw one of these for a few years but they used to have a problem with the harness chaffing on the underside of the timer as well as the usual module/motor problems you get on the Servis models.Timer faults were rare on this one.
    If it is a motor or module get the number printed on the part as you will get the parts at a fraction of the price from AWS
    John
    #357957
    johnnyj
    cheers john
