Hi i have a Whirlpool AWG349/3 which i repaired a dry joint on the main pcb (the machine was just locking the door and not doing anything else). The machine now goes through the wash and rinses but won’t finish the final spin, it spins for a few minutes(i would say a full spin time). The machine then stops spinning and pumping for a few moments then starts distributing and then spinning again. It continues doing this until it is turned off. I have checked brushs, heater and water valve they are all fine. Would this be a timer fault or main board? any help would be really appreciated
Thanks Peter
Thanks Martin i must admit i didn’t check that, i kind of assumed that as it was spinning it would be clear. I will try that but if it doesn’t work i will give up i think, the module and timer are to expensive to gamble on.
