Whirlpool awg5122 bearings
  • #48974
    mjw1208
    Any body know if the bearings are available for this 15month old washing machine and from where , is it a vestel made machine ? shame to landfill it !!
    #298353
    jackster
    Re: Whirlpool awg5122 bearings
    Looks like a rear half job, not cheap either!
    Part No: 481202308027 – £173 on sios, not surehow much from masterpart etc, its not listed.
    #298354
    Maybe it would be worth offering to dismantle it for £X on the basis that if the parts inside turned out to be unobtainable you would call it BER only at that point. My guess is there’s a good chance they’ll be common sizes. Even unusual seals can often be substituted with a similar size.
    Mike.
    #298355
    mjw1208
    Yes that’s the avenue we thought about going with this machine, customer already had someone out to it before us and condemned it as b.e.r. without taking top off machine , though it does look repairable – split tub etc. and we need the work (and money) even if some engineers don’t
    #298356
    mjw1208
    Yes same bearings 6205zz and 6206zz as used in the fast spin beko washers (buy it as a beko bearing set and get the seal as well ) proper job !!
