Hi All, Been to this machine today that has some strange faults.
On any prog you select the pump starts to run straight away, the machine starts to fill with the pump still going at the same time at no point could you see any water in the drum.
When I turned the timer knob to stop, the machine just pumped and the door open light was lit along with the water stop light.
The only thing I could get it to do ok was the spin cycle.
Thanks in advance, Ray
