Regardless of programme the machine does the same thing.
Fills approx 6 secs, stops filling for approx 10 secs, fills again for approx 6 secs.After approx 90 secs, the water stop light illuminates. During the whole of this time, the drain pump is running. Then the water stop light remains illuminated and the drain pump contiues to run until it is switched off. I suspect there may be a sump float switch involved. Again this is an integrated appliance, which looks awkward to remove. Can anyone help?
Cheers
