Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › whirlpool awm 1000
- This topic has 8 replies, 3 voices, and was last updated 13 years, 1 month ago by
robie5.
March 4, 2013 at 9:58 pm #74424
robie5
ParticipantHi all newbie here. Ok have a whirlpool awm 1000. When you start it it clicks twice and nothing for 60/90 seconds tries to start then nothing. I thought it might be door locking mechcanism but some posts say “brushes”. Are these hard to fit or do I need engineer. thanks in advance robie
March 5, 2013 at 12:12 am #391528kwatt
KeymasterRe: whirlpool awm 1000
What’s the 12NC number and do any lights flash?
March 5, 2013 at 6:16 am #391529robie5
ParticipantRe: whirlpool awm 1000
nc number is 857020215200 there is no lights with this model thanks
March 5, 2013 at 7:01 am #391530kwatt
Ah, it’s one of the old Servis type ones.
Door lock or carbons are both possibilities I suppose but does it even fill?
March 5, 2013 at 9:11 am #391531robie5
Thanks kwat no it doesn’t fill .Also I always found I had to give the door a nudge to start. ARE brushes easy to fit? Thanks
March 5, 2013 at 9:42 am #391532Martin
robie5 wrote:Also I always found I had to give the door a nudge to start.
And even that now doesn’t do the trick, right? Then I would venture to suggest the door interlock may well need replacing to cure the problem.
robie5 wrote:ARE brushes easy to fit? Thanks
Not too bad, why do you ask? A quick glance at the motor and you’ll see what I mean.
March 5, 2013 at 9:59 am #391533robie5
Thanks Martin will try door first. Looked at motor last night looks like they just plug in. Would I be right? Girl in shop said to get a repair man to do it. ALSO how do I know if brushes need changing?
March 5, 2013 at 10:50 am #391534Martin
robie5 wrote:Looked at motor last night looks like they just plug in. Would I be right?
10 out of 10 for observation.
robie5 wrote:ALSO how do I know if brushes need changing?
Ah! For that you will first need to remove them and look to see if there is plenty of carbon left on the end of each. (minimum 15mm)
If you are the least bit hesitant over any of this then “the girl in shop” may well be right! 😀
March 5, 2013 at 9:27 pm #391535robie5
thanks for the help kwat and martin. Turned out to be the door lock easy fix
