Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Whirlpool awm 1000 drum jamming
- This topic has 7 replies, 2 voices, and was last updated 11 years, 10 months ago by
King2.
May 26, 2014 at 5:44 pm #80812
King2
ParticipantI have a whirlpool awm 1000 bought in 2003, light usage, used once every 10 days or so. I used it today and the drum would start rotating normally and then stop accompanied by a squeal, slipping belt I presume. The drum would start rotating again then for a few turns and jam again.
I emptied the machine and then tried to rotate the drum by hand which took a fair bit of force. I removed the rear cover and took the belt off and tried to rotate the drum pulley and it was still jammed. It freed up again after turning it over by hand for a while and seemed ok.
I loaded the machine up with the wet clothes and put it on spin. It spun for about 30 secs and then got very noisy again and I switched it off,the Drum jammed again.
Can someone tell me Whats causing this? Thanks
May 26, 2014 at 6:00 pm #414406Martin
ParticipantRe: Whirlpool awm 1000 drum jamming
Drum support shaft (aka Drum spigot) cracked probably. If the inner drum has a slight wabble in relation to the tub and touches the door seal as it goes round that confirms it.
May 26, 2014 at 8:51 pm #414407King2
when the Drum is jammed and I turn it by hand it will free out and then appears to turn completely normally,cant see any wobble in it.
May 26, 2014 at 8:53 pm #414408Martin
Sock caught between drum and tub? Use a torch to spot it.
May 26, 2014 at 10:20 pm #414409King2
I was thinking that, looked around inside the door between the drum and tub but couldnt see any obstruction, sock could be gone in totally out of view? If so would the Tub and drum have to be dismantled to remove it?
May 27, 2014 at 6:29 am #414410Martin
King2 wrote:If so would the Tub and drum have to be dismantled to remove it?
Undoubtedly yes!
May 27, 2014 at 10:44 am #414411King2
Got lucky!,managed to locate sock by sticking small screwdriver through holes in drum.The sock got lodged at the tub drain point so managed to pull it through the drain hole after removing drain hose.There was a small plastic ball about size of ping pong ball floating in water at top of the drain hose. Is that supposed to be there?
May 27, 2014 at 1:54 pm #414412Martin
Yes, leave the ball valve well alone!
