Re: whirlpool awm 323 not running
Obvious question – does the door actually lock? If it does, the lock is not the problem.
These machine perform a “self check” on start up. If the motor or the pump specifically are out of circuit, it won’t go. Motor brushes is the common one quoted on these forums, but wiring issues are common. Pump wires break at the connector block and motor wires break in the support across the front of the tub and occasionally in the motor plug.
Stay safe, power off first, please.
