Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWM 6100/3 not emptying or going to spin
- This topic has 15 replies, 4 voices, and was last updated 18 years, 7 months ago by
Seamy.
September 7, 2007 at 9:23 am #30362
Seamy
ParticipantI have a Whirlpool AWM6100/3 not emptying or going to spin.
When pump out is selected it will empty, when spin only is selected it does spin.
When watching programme strange buzz sound & motor seems to advance drum 1mm at a time. But doesn’t revolve as normal.
I have taken blockage from filter & cleaned armature & checked that there is good length on carbon brushes.September 7, 2007 at 12:44 pm #226896richardable
ParticipantRe: Whirlpool AWM 6100/3 not emptying or going to spin
a while ago i chased this fault and found…blocked air tube/bottle.
front panel off and the air tube to the pressure swich is on the front of the tub. check for sludge/ debris.
richardSeptember 7, 2007 at 1:07 pm #226897Seamy
Already thought of this & checked it thanks for reply.
A few points though, when I blew into pressure switch, there was only one click, is this correct?
Also customer has contacted me & said that machine will work in Rapid Wash setting. Which i find strange..September 12, 2007 at 8:37 am #226898Seamy
OK back to same fault, Electronic buzzing, pulsing sound coming from electronics, drum will advance a few milimeters at a time but won’t go into spin. Motor looks healthy, brushes are good & armature clean.
Tacho also looks & meters ok.
I was wondering is there any test or reset procedure for this machine?
Do Electronic Controls cause much grief on this model, I don’t see an awful lot of Whirlpool.September 12, 2007 at 9:20 pm #226899admin
KeymasterIf he makes spin program till “End” then motor; pumps, pressure switch is OK.
Enter into service mode end see what will say…
I will rewrite memory program first.September 12, 2007 at 9:27 pm #226900senseib
Sure pump not sticking!!!
Brian.
September 13, 2007 at 7:45 am #226901Seamy
HELLO…
How do I “Enter into service mode” ?
Water is drained out of machine, pressure vessel is not blocked.
September 13, 2007 at 8:11 am #226902admin
Keymasterseamus@cruddenelectrical.co.uk
Is this your mail?September 13, 2007 at 8:36 am #226903Seamy
Yeah Baron, that will get me..
ThanksSeptember 13, 2007 at 9:26 am #226904admin
KeymasterRe: Whirlpool AWM 6100/3 not emptying or going to spin
It is on your mail pocket 😳 8)
September 13, 2007 at 1:19 pm #226905richardable
baron, if it’s not too much trouble could you send me a copy too. 8)
richard.September 13, 2007 at 1:36 pm #226906Seamy
Thanks Baron
September 13, 2007 at 8:30 pm #226907admin
KeymasterRichard :innocent:
http://www.eserviceinfo.com/downloadsm/ … M6100.htmlSeptember 13, 2007 at 9:43 pm #226908richardable
baron, thankyou. 😀
richardSeptember 14, 2007 at 8:20 am #226909Seamy
Thanks for that I do have a Whirlpool Sios disc from 2002 but this model wasn’t listed, can I do a software download to update it with recent machines (if so from where) or do I have to get a new disc?
