Whirlpool AWM 6100/3 not emptying or going to spin
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool AWM 6100/3 not emptying or going to spin
  • #30362
    Seamy
    I have a Whirlpool AWM6100/3 not emptying or going to spin.
    When pump out is selected it will empty, when spin only is selected it does spin.
    When watching programme strange buzz sound & motor seems to advance drum 1mm at a time. But doesn’t revolve as normal.
    I have taken blockage from filter & cleaned armature & checked that there is good length on carbon brushes.
    #226896
    richardable
    Re: Whirlpool AWM 6100/3 not emptying or going to spin
    a while ago i chased this fault and found…blocked air tube/bottle.
    front panel off and the air tube to the pressure swich is on the front of the tub. check for sludge/ debris.
    richard
    #226897
    Seamy
    Already thought of this & checked it thanks for reply.
    A few points though, when I blew into pressure switch, there was only one click, is this correct?
    Also customer has contacted me & said that machine will work in Rapid Wash setting. Which i find strange..
    #226898
    Seamy
    OK back to same fault, Electronic buzzing, pulsing sound coming from electronics, drum will advance a few milimeters at a time but won’t go into spin. Motor looks healthy, brushes are good & armature clean.
    Tacho also looks & meters ok.
    I was wondering is there any test or reset procedure for this machine?
    Do Electronic Controls cause much grief on this model, I don’t see an awful lot of Whirlpool.
    #226899
    If he makes spin program till “End” then motor; pumps, pressure switch is OK.
    Enter into service mode end see what will say…
    I will rewrite memory program first.
    #226900
    senseib
    Sure pump not sticking!!!
    Brian.
    #226901
    Seamy
    HELLO…
    How do I “Enter into service mode” ?
    Water is drained out of machine, pressure vessel is not blocked.
    #226902
    seamus@cruddenelectrical.co.uk
    Is this your mail?
    #226903
    Seamy
    Yeah Baron, that will get me..
    #226904
    It is on your mail pocket 😳 8)
    #226905
    richardable
    baron, if it’s not too much trouble could you send me a copy too. 8)
    richard.
    #226906
    Seamy
    Thanks Baron
    #226907
    richardable
    baron, thankyou. 😀
    richard
    #226909
    Seamy
    Thanks for that I do have a Whirlpool Sios disc from 2002 but this model wasn’t listed, can I do a software download to update it with recent machines (if so from where) or do I have to get a new disc?
