Whirlpool awm 8143 washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool awm 8143 washing machine
  • #29852
    redjumperjohn
    help? when in wash mode the drum speeds for a couple of seconds up as if it was about to spin sometimes it will finish the cycle ok but other times it shuts its self down
    Sometimes it remembers where it was when you reset it.
    Everything else works as it should
    Do you think its major or fixable its 7 years old
    Thanks John
    #224935
    Ritch
    Re: Whirlpool awm 8143 washing machine
    sounds like a motor tacho problem could be as easy as a loose wire to motor a broken wire or just chaffed through if you are going to investigate yourself them make sure that you remove the mains plug as washing machines can kill!! call an engineer if you are not sure.
    #224936
    redjumperjohn
    Thanks Ritch
    Nothing seems loose
    I take it that would be a new motor then?
    thanks John
