Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Whirlpool AWM 8163 washing machine – Error
- This topic has 6 replies, 3 voices, and was last updated 19 years, 6 months ago by
potnoodle.
September 22, 2006 at 10:50 am #21058
potnoodle
ParticipantMy washing machine starts up washes for alittle bit and then stops and then flashes F P ,does anyone know what this means?
September 22, 2006 at 11:07 am #189322DDSDDS
ParticipantRe: Whirlpool AWM 8163 washing machine – Error
it means your machine has not drained have you checked the filter?
September 22, 2006 at 8:22 pm #189323potnoodle
DDSDDS wrote:it means your machine has not drained have you checked the filter?
Hi, yea we have now checked the filter and pump and they were blocked,so i put a load of washing in on a 40 synthetic wash,everything was going well untill about 16mins left on the wash and it stopped and that error came up again,i then drained the machine and that worked fine so i put it on the rapid quick wash cycle and that cycle works, so when that was finished i tried the 40 synthetic wash again and the same thing happened again.
hope you can help,
thanksSeptember 23, 2006 at 5:41 pm #189324Penguin45
The pump motor itself may be on its way out. A 5p will exactly fit the outlet tube of the pump and may act as a part-time flap valve. If the machine is connected to an undersink spout, strip and check the coupling.
Power off if dismantling the pump.
Penguin45.September 26, 2006 at 11:15 am #189325potnoodle
hi. Sunday morning i noticed the sink was draining slow so i used sink and drain unblocker and after that the machine worked perfect all day sunday. then yesturday morning the error came up again ,we checked the filter and the filter was clear but propellor wouldnt go round but if you put a pencil and touched propellor it drains or even if you bang the filter it drains,so we are now extremely puzzled as to what the problem is ,hope you can help , thanks
September 26, 2006 at 6:55 pm #189326Penguin45
Classic worn pump symptoms. You need one of these:
http://www.ukwhitegoods.co.uk/modules.p … cts_id=161
Penguin45.September 27, 2006 at 7:49 am #189327potnoodle
Penguin45 wrote:Classic worn pump symptoms. You need one of these:
We ordered one yesturday just in case, im glad we did now!Just wanted to say what a great site this is and thanks alot for the help 😀
