Whirlpool AWM029 washer stopping mid-cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool AWM029 washer stopping mid-cycle
  • #43675
    Hooch
    My washing machine has decided to stop mid-cycle… seems to fill and wash OK, but just stops when it gets to the spin bit. I did notice a sort of clunking noise the other day which sounded horribly like the drum was coming loose. Not sure if this is related or not, but the power button seems to be a bit temperamental too – you have to press it in at a slight angle or it won’t turn on.
    I love my machine, really…
    Any advice would be hugely appreciated! 😕
    #278085
    Re: Whirlpool AWM029 washer stopping mid-cycle
    Water still in it?
    Hooch
    Yes, a little water still in. Not the full amount, but definitely some (you can open the door without it spilling out). I’ve checked the filter and the pipe where it drains into the u-bend, and they’re clear.
    #278087
    Hooch
    Any thoughts – DIY/engineer/new machine??
    #278088
    Select spin with the filter removed and see if the pump actually runs.
    Hooch
    Will give that a go… Thanks 🙂
    #278090
    Hooch
    Nothing happens at all – water comes in and some of it drains away but the drum doesn’t move…
