Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWM049/3 fast advacing??.
- This topic has 5 replies, 3 voices, and was last updated 19 years, 12 months ago by
TELL.
April 15, 2006 at 5:55 pm #17165
TELL
Participantthe above m/c will not start on a prog, when drain selected, it does a pulse drain then stops, (it does this at start of all other selected prog’s).
it then starts to advance a few pulse’s, pause’s, then starts to advance again till it eventually drains then stops, when this is done, it keeps advancing??. set onto a spin prog, again it pulse drains momentarily, then starts to fill?, washes then starts the advancing sequence again, till it eventually stops ,and drains,Phew!!.
anybody out there can help please,
thanks TELL..April 16, 2006 at 7:01 am #173183Martin
ParticipantRe: Whirlpool AWM049/3 fast advacing??.
These programme timers often have a ‘skipping fit’ when the whole circuit is interrupted. (i.e. blocked air chamber, chafed wiring harness, low insulation on heater etc)
April 16, 2006 at 7:06 am #173184funkyboogy
most probaly a motor fault…had this one recently,fitted everything bar the kitchen sink.???>>>called a mate who works with W/P…who had great joy in telling me it didnt need all the parts i had fitted,it just needed the motor..
still it was fun…notApril 17, 2006 at 9:44 am #173185TELL
i have checked heater, and motor resistance etc, they seem to be normal readings i would expect. the carbon brushes were ok. and the level of water ok. the motor does tumble, but the programmer does not give it a chance to do anything else.
TELL..April 18, 2006 at 7:14 am #173186Martin
TELL wrote:its a whirlpool AWM049/3 fast advancing. wont start on a selected prog, or spin etc. the motor does tumble, the m/c does drain eventually, after it has advanced through progs a couple of times. any idea’s?
thanks TELL..I’ve just added your post to the original thread Tell, keeps it ‘neat & tidy to stick to one thread please 🙂
Incidentally, have you checked the heater on it?
April 18, 2006 at 8:17 am #173187TELL
heatter checks out ok, martin
TELL.. -
