Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWM049 int. washer
- This topic has 7 replies, 5 voices, and was last updated 16 years, 6 months ago by
mikewillner.
October 9, 2009 at 3:00 pm #49209
mikewillner
ParticipantHelp, This machine is failing to pump out we have unblocked and changed pump it is completely clear, there is a chamber at top of machine thewaste pipe goes to first thewater hardly reaches this chamber, as if the pump has lost power??? Any suggestions. Thanks
October 11, 2009 at 5:09 pm #299128leavemetogetonwithit
ParticipantRe: Whirlpool AWM049 int. washer
Does sump hose have a table tennis ball in it? If so, try removing it. Better still, try and observe the sump hose when machine is pumping. Is it getting crushed by vacuum pressure?
Mike.July 1, 2010 at 2:13 pm #299129mbdas
HI 🙂
I’m having the same problems have done all that and removed eco ball but still the same 🙁 did you sort this out ❓
thanks mark 😕July 1, 2010 at 2:20 pm #299130leavemetogetonwithit
Wonder if pump is getting full 240v?
Mike.July 1, 2010 at 7:32 pm #299131mbdas
have not checked voltage but can’t see how it couldn’t get 240v you would think it would or would not ❓ I’m a bit stuck with this one 😕 for sutch a simple fault 😥
July 1, 2010 at 8:26 pm #299132leavemetogetonwithit
Only thing I’ve ever had of the like was a Zanussi Askoll where the impellor shaft was actually loose inside the magnet of the rotor. But you implied that you have changed the pump so I assume it’s not that.
I assume you’ve had sump and drain hoses off and tipped out any loose coin or colourcatchers.
It’s not impossible for a pump to get a reduced voltage if its supply comes via a relay or a triac and there’s a burnt terminal or dry joint for example. Best way to check would be to try powering it from a seperate mains lead.
One last thought, could there be a blockage somewhere preventing air getting into the top of the drum? Try pulling out soap dispenser?
Mike.July 1, 2010 at 10:27 pm #299133johnmac11
Mike has a point about the pump not getting the full 240v, I have saw a timer problem causing reduced voltage to the pump on more than one occasion.
John
July 2, 2010 at 9:51 pm #299134adv
if the impellers goin round must be blockage in hose somewer?
