Whirlpool AWM049 “water Stop lamp”
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool AWM049 “water Stop lamp”
  • #11424
    My Whirlpool washing machine has stopped operating correctly. It starts a cycle and then appears to get stuck at the beginning of the cycle, the Water Stop light is illuminated.
    Any ideas ??
    #145312
    Re: Whirlpool AWM049 “water Stop lamp”
    Most likely the machine has an internal leak or that the drain filter is blocked. Check that out first and if there is still a problem let us know 🙂
    #145313
    Martin.
    Thanks for your advice. I did as you suggested but found no blockage or leak, however the machine started working correctly so possibly the leak is an intermittent one that dried out by the time I got to checking, it is intermittent or we used too much soap powder…
    I’ll keep an eye on it to see if it returns, but as I say, Thanks for yoru help.
    #145314
    scott robertson
    i also have a problem with water stop light coming on, usually just before spin cycle.took back off machine and base had water in it,the water had triggered the float switch which stopped water. i dried it up and machine worked ok for 2 washes then same problem.has anyone had a similar problem?
