We have the Whirlpool awm219 and it recently ended its extended 10 year warranty.
The proble is that the machine will not drain the water after a wash. i have taken out the filter and checked the pipe for blockage but think the problem could be the pump. i can drain the water after selecting the drain setting approx 5 or six times but maybe the pump isnt pushing the water up the pipe?
The machine is never quite empty. You say that you can drain it after 5 or 6 attempts – is this with the pump running, or does it take that many goes to get it running? If the former, yes there is a blockage somewhere – sock in the sump hose, 5p in the pump outlet for instance. If the latter, the pump may well be worn – have a read of this: http://www.ukwhitegoods.co.uk/modules.p … ge&pid=160
