Re: Whirlpool AWM321/3 dribbling from door. No dirt,distorti
check the soap dispenser drawer, if it leaks it will cause a slight dribble which usualy runs down and around the door making you think it is a seal/door leak.
If you remove the drawer front and put appliance onto a rinse you should see a small drip running down the green liquid siphon that is slotted into front of drawer, if it is leaking you can either change the outer drawer, try cleaning the jets above the conditioner compartment or go for the easy fix which is to through the green siphon in the bin. If you take the siphon out it will still drip but the water will run with the contour of the drawer and go back inside the dispenser body.
John
