Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › whirlpool awm321 won’t spin
- This topic has 14 replies, 3 voices, and was last updated 18 years, 9 months ago by
chrismv6.
July 3, 2007 at 7:22 pm #28693
chrismv6
ParticipantEvening all
Whirlpool awm321 won’t spin, does the rest of the cycle but at spin time only goes round at normal washing speed. Checked the brushes and it’s emptying out ok…a bit stumped now 😕 , any ideas anyone?
Many thanks
ChrisJuly 3, 2007 at 8:12 pm #219594Penguin45
ParticipantRe: whirlpool awm321 won’t spin
Water level control system? If it thinks it’s full of water, it won’t spin.
Power off if you choose to investigate.
Penguin45.July 3, 2007 at 8:27 pm #219595realengineer
he hello
replace door interlock and jobs a goodena belgium lost in uk
July 3, 2007 at 10:37 pm #219596chrismv6
Thanks for the replies guys!
Forgot to say the water level switch seems to be working ok (pump comes on if you blow into it and goes off when you stop).
Would the door interlock affect only the spin part of the cycle?
ChrisJuly 3, 2007 at 11:53 pm #219597Penguin45
Check the obvious – is the door locked?
July 4, 2007 at 7:30 am #219598realengineer
YES indeed the old door lock has a switch on it
switches the spin on or ofa belgium lost in uk but know s it the doorlock believe me 😆
July 4, 2007 at 9:56 pm #219599chrismv6
Ok, if the door interlock was knackered the machine would not run through a cycle which it does, the only thing it won’t do is spin at full speed. So unles I’m being stupid (always a possibility 😆 ) I can’t see it being a door lock fault or can it?
Thankyou for your time!
ChrisJuly 4, 2007 at 10:38 pm #219600realengineer
ofcource u right
am just a belgium
but if u would have a interlock that turns on machine and also aa safety feature meaning 2 switches one to start and one to protect against spinning whiles door openas i say prove me wrong replace interlock if not i come and fix the machine myself free of charge
am stupid but it did happen to me
no spin IS THE INTERLOCK
8)
July 4, 2007 at 10:40 pm #219601realengineer
just do it replace interlock
tell the world i was rightdo it do it
do itthank you
July 5, 2007 at 5:44 pm #219602chrismv6
Oh alright then I’ll do it! Didn’t realise it would be a two stage kind of thing. It might be a rash promise to come and fix the machine as I live half a mile from Lands End….a longish old way from Manchester! Mind you easier than coming from Belgium 😀 .
I’ll let you know how it goes and thankyou for your time and trouble.
ChrisJuly 5, 2007 at 8:09 pm #219603realengineer
well you need forgners to get the job done
8)
July 26, 2007 at 10:02 pm #219604chrismv6
Just to let you know I finally got round to getting and fitting a new door switch and what do you know….it worked!!! So many thanks for your advice, you know what they say “never doubt a Belgian”! 😆
Thanks again
ChrisJuly 27, 2007 at 6:49 pm #219605realengineer
good i could be at help
July 27, 2007 at 7:35 pm #219606chrismv6
Oh Damn!! 🙁
When I fitted the door switch I tested the spin and it spun up a treat but a load of washing has now come out wet so not spinning again. The first thing I checked when all this started was the brushes, plenty of life left in them, so any other ideas please?
ChrisJuly 27, 2007 at 10:17 pm #219607realengineer
ooooooooooooo
check nothing in sump socks smalls etc
is the drainpump working
motor wireing
last timer
is it draining fast enough
is the filter clean
wireloom
then timer
then call a whirlpool engineer
if possible a forgn one hahaha
