Whirlpool AWM336…needs new pump I think
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool AWM336…needs new pump I think
  • #20494
    flyingmonkey
    Hi all
    Our 7 year old washer keeps sticking on cycles and not going on to rinse.
    I have read through this site and others and I think it is too old to have electronic load balancing. Looking at a few of the posts on here it looks like it needs a new pump.
    I am reasonably competent with electronics but would it be cost effective to repair the washer or is it time for a new one?
    Nick
    #187243
    gegsy
    Re: Whirlpool AWM336…needs new pump I think
    Hi Nick
    It could be faulty fill valve,heater or thermostat also. Pump if required is around the £53.
    In what way does it stick ie- what can you see and hear?
    Un plug appliance if you are going to fault any further :plug:
    flyingmonkey
    Thanks for quick reply.
    It sticks as in the dial gets to a certain point (usually a or b) and then all that happens is that the drum just fills and drains as if it is at start of the cycle (good job we’re not an a water meter).
    If I manually jog dial on it kicks back into life.
    Tonight I had to mess around for ages to even get the washer to go past the fill cycle.
    Nick
    #187245
    gegsy
    Hi Nick
    Sounds like a possible blockage in the fill pressure system and/or timer problem.
    Without being hands on its hard to tell 😕
    You may want to consider an engineer. Please use the link below to find one.
    Regards
    flyingmonkey
    Many thanks – I will get some quotes.
    #187247
    flyingmonkey
    Just had some good news: after checking all our warranty info it turns out that we registered for the Whirlpool 10 year parts guarantee.
    I phoned Whirlpool to make sure we wouldn’t get stung for labour, etc and all we pay is £72.50 and that covers all the labour costs until the problem is fixed.
    Looks like a good deal so I will go with this option unless anyone knows of a reason not to?
