Whirlpool AWM5125/? worth doing bearings?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool AWM5125/? worth doing bearings?
  • #64226
    Had a quick peek at this today. Bearings only beginning to go so could catch them early. But the split tub is held together by numerous (~30?) metal clips which, if my suspicions are correct, won’t come off easily. Has anyone done one of these? I know the genuine parts would be expensive but I could easily use another mnufacturer’s bearings and maybe even find a cheaper seal.
    This model doesn’t apparently have the pull-out hub.
    Mike.
    #356445
    johnmac11
    Re: Whirlpool AWM5125/? worth doing bearings?
    Hi Mike,
    Just stick a large flat bladed screwdriver behind each clip and force them off, when rebuilding, line each clip up and tap with a hammer and they will go back on quite easily.
    John
    #356446
    Hi John, Thanks for the info. Original seal seems to be 35x65x9 according to Connect. I’ve ordered a 35x65x10 which is nearest I could find for much less money and probably just as good.
    If you think of anything which is likely to trip me up first time I do this one, please let me know as I really need to do it in one hit.
    Mike.
    #356447
    johnmac11
    Easy job Mike, should take about 45 mins.
    John
    #356448
    Friday afternoon awaits. I’ve allowed a bit more than 45 minutes 😉 .
    Mike.
    #356449
    Job was a cinch, just like John said :tup: . Wish I could find a few more like that. One thing to note, pulley nut is 18mm – not something you come across every day.
    Mike.
