whirlpool awm5145/3
  • #6575
    tonyclifton
    Blocked
    got above machine to recon but on timer does is makes 2 clicks then nothing checked pump,interlock, motor through only got 157volts to motor think timer 💡 any one know were to get cheap one or just dump machine ❓
    #118405
    Re: whirlpool awm5145/3
    hi,
    can you supply 12nc number begining with 85……..
    I have a little stock left from my whirlpool days
    kevin
    ps anyone after dreamspace spares should ask…
    #118406
    tonyclifton
    Blocked
    857051415230 8)
    #118407
    hi,
    part number 481228219575 will look in the morning and pm you
    kevin
    #118408
    SL
    this is a motor fault, these machines rotate the motor first before they fill, check the motor wiring, brushes etc
    #118409
    I have a similar problem with one of these machines in that you switch the machine on, the timer/module unit makes a whirring sound then nothing?
    I suspect the interlock in my case as the door doesn’t lock, but from other postee’s suggesting motor brushes and stuff. I was wondering, would duff motor brushes not allow the interlock to work? 😕
    …..or should I just order an new Interlock and give it a whirl first? :con:
    #118410
    SL wrote:this is a motor fault, these machines rotate the motor first before they fill, check the motor wiring, brushes etc
    x2 – more than likely it is the brushes or a broken wire on the motor plug.
    they can break right on the actual motor plug and sometimes you have to give the wires a little tug just to see if one snaps.
    #118411
    Bryan
    Martin wrote: I was wondering, would duff motor brushes not allow the interlock to work? 😕
    Not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure Martin , but from memory worn out brushes would still allow the door interlock to “lock on” but machine won`t do anything else.
    Bryan
    #118412
    Bryan
    x2, brushes will cause the door to lock, but not to start.
    #118413
    kandl-appliancerepair wrote: brushes will cause the door to lock, but not to start.
    It was the just Interlock at fault in my case. I did check things like brushes etc and they were OK. 🙂
    One thing I did notice was that with the duff interlock in place only the timer made a short whirring sound then nothing – dead! After I fitted the new interlock, the moment you set it on any cycle, the first thing it does, in addition to the timer whirring, is energise the inlet valves and the motor (all done in a split second by the way, which proves the machine interrogates all components before actually starting).
    Very interesting observation I thought and one to watch out for on the next Whirlpool I come across 8)
