Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWM6140/3
- This topic has 12 replies, 4 voices, and was last updated 18 years, 5 months ago by
Alanj.
October 31, 2007 at 12:38 pm #31828
Alanj
ParticipantHi Guys,
went to this appliance this morning, fault as follows – machine fills, with motor action in both directions, once water intake stops machine is quiet for a few seconds and then the following lights start flashing – wash light, start button light and 800 and zero spin lights. Anyone got an answer? I have checked the error codes but couldn’t find anything related.
Ihave checked the motor brushes, heater and inlet valves. Thermistor on heater reads 1997-1999ohms.Alan
October 31, 2007 at 4:18 pm #232643robwash
ParticipantRe: Whirlpool AWM6140/3
hi…F9 = overfill. check pressure bottle and pressure switch
October 31, 2007 at 4:20 pm #232644robwash
sorry 1 question. Whats the spin speed of the machine? zero and 4th light up is F9 and zero and 3rd light up is F5 ntc failure
October 31, 2007 at 8:50 pm #232645Alanj
Hi Robwash,
thanks for the reply.It is zero and third light up. I thought it might have been an ntc fault, but wasn’t sure what reading ntc on heater should be. Heater tested out ok.
Alan
October 31, 2007 at 8:53 pm #232646Alanj
by the way where did you get the fault codes from, for that model? I couldn’t find them listed on the known error codes. Are they on the Sios disc and if so where?
Alan
November 1, 2007 at 6:45 pm #232647robwash
I do sub-contract work for them so I’ve got all the data. send me your fax no and i’ll send you the page with all the lights and faults. It should be on sios but this is easier.
November 5, 2007 at 7:34 pm #232648Alanj
Hi Robwash,
have pm my fax no to you.
Alan
November 5, 2007 at 10:59 pm #232649squadman
Re: Latest SIOS
How much useful technical data has SIOS got on it ?
I have a older version of SIOS and although there are wiring and cam charts which are useful there is not much in the way of fault code or K type sheet information.
Does the current version of SIOS address this ?
How much is SIOS ?
November 6, 2007 at 8:01 am #232650johnmac11
squadman wrote:or K type sheet information.
I haven’t heard that one for years, brings back memories of thousands of microfeche 😆
It is only the very old models on SIOS that dont have tech info and diagnostics. Just about all of the models on SIOS now have wiring diagrams, resistance readings,fault codes and diagnostic programs. The main problem I find with SIOS is that it does not include service bulletins / K sheets
IIRC it costs around £35 per year.
JohnNovember 6, 2007 at 10:43 pm #232651Alanj
[Johnmac11 wrote] Just about all of the models on SIOS now have wiring diagrams, resistance readings,fault codes and diagnostic programs.
Where do you get this info on Sios?
Alan
November 6, 2007 at 10:59 pm #232652johnmac11
Alanj wrote:Where do you get this info on Sios?
often missed, look under “components” it is all there..
John
November 7, 2007 at 5:22 pm #232653Alanj
Hi johnmac11,
cheers john! I’ll have a look 😳
Alan
November 7, 2007 at 5:24 pm #232654Alanj
By the way, robwash, machine is fixed 8) so thanks a lot for your help 😉
Alan
