Whirlpool AWM6141/1
  • #16900
    johnnyhoz
    Does anyone know what Faultcode F06 is?
    john
    #172074
    Re: Whirlpool AWM6141/1
    johnnyhoz wrote:Does anyone know what Faultcode F06 is?
    john
    Did you not find it in the “Known Error Codes” thread then Johnny?
    http://www.ukwhitegoods.co.uk/modules.p … c&start=15
    #172075
    johnnyhoz
    Sorry Martin didnt realise there was more than one page of fault codes
    Cheers
    john
    #172076
    No problem mate, hope you get it fixed OK?
    #172077
    johnnyhoz
    F06 fault is Tachometer failure (no motor movement detected)
    The machine acts normally on lower spin speeds but set on 1500 top speed it cuts out and gives F06, has anyone come across this fault?
    I’ve checked the security of the tacho the brushes are fine the comm looks good.
    john
    #172078
    Alanj
    HAVE YOU CHECKED FOR BROKEN WIRES AT MOTOR PLUG/WIRING LOOM?
    #172079
    johnnyhoz
    Yes everything looks normal
    john
    #172080
    Alanj
    Hi John,
    did you give the wires a pull at the motor plug to make sure they weren’t just holding by the pvc sheath?(broken inside)
    Alan
    #172081
    johnnyhoz
    Yes but I’ll Recheck
    thanks
    john
