WHIRLPOOL AWM6145/3 – STICKS WITH 1MIN ON DISPLAY
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries WHIRLPOOL AWM6145/3 – STICKS WITH 1MIN ON DISPLAY
  • #19588
    bruce118
    Have got a intermittant problem with this machine where it sometimes sticks with 1 min left on display with pump running? Have checked heater, NTC and valves, but all appear to check OK. Has anyone had this problem B4? Bruce.
    #183745
    Dave_Conway
    Re: WHIRLPOOL AWM6145/3 – STICKS WITH 1MIN ON DISPLAY
    Moved to the trade area Bruce 😉
    Blockage in the pressure system maybe ?
    #183746
    bruce118
    Returned to reasses fault but desturbing connections last visit seems to have cleared fault , going fine now. Thanks meantime. Bruce 🙂
    #183747
    johnmac11
    Have not saw this one for a while.
    It is caused by a bad connection between the motor plug and socket on the orange wire to the field coil.
    John
    #183748
    Just had one of these today, she says she thinks she once saw FH ( no fill ) but recently it has got to the end of spin and stuck with 1 min on display and she can hear a clicking noise which she thinks is the door. If she then sets it to Drain it will complete that cycle, switch OFF and the door can then be opened.
    I set the machine to spin and it went straight through the full 15 minute cycle and switched OFF perfectly. 😕
    I did notice that on checking the filter it apppeared to be well gunged up with soap residue, wondering if a partial pressure hose blockage could be the cause of this fault. ❓
    PS. Just reading the first post, apparently this one switches off the main motor & pump and just leaves the ‘clicking’ noise.
    #183749
    SparkyP
    Hi THere,
    Just to confirm Johnmac11 is correct it is a bad connection between motor loom and motor plug. Orange wire has bad connection or loose. If in doubt change motor loom. Then job will be sorted.
    Sparkyp
