Hi Guys
Need some help on this one.
The waste pipe had come off the drain pump and activated the anti flood.
Put it all back together, mopped up the water, tested it and all worked fine.
When i tried it again it fills for a second, then the pump just runs and runs as if the anti flood has been activated, but no leaks anywhere?
The other weird thing is the pump runs even when the machine is turned off. Has to be unplugged to stop it.
