Whirlpool AWM8103
  • #19084
    Customer just phoned.
    Set programme, machine starts to fill for about 10 seconds then ‘door open’ light flashes and machine stops.
    Is this just a dodgy door lock or do I need to look elswhere?
    #181663
    gegsy
    Re: Whirlpool AWM8103
    Sounds like a door problem; as in catch or interlock Jim, anything else and it would put an error code up.
    I remember some of the newer Zanussi doing this very fault, whatever relevence that has 😀
    Will, ‘suck it and see’
    Jim. :tup:
    #181665
    mbdas
    Hi 🙂 I went to one the other day customer had fitted a new door switch before calling me and that turned out to be just the carbons
    mark 🙂
    #181666
    johnmac11
    mbdas wrote:Hi 🙂 I went to one the other day customer had fitted a new door switch before calling me and that turned out to be just the carbons
    mark 🙂
    I think Mark has got it, saw a few of these with wierd and wonderful faults and the first thing to check is the carbons.
    John
    #181667
    SparkyP
    Hi Iadom
    It is definately the carbons 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure. When the door locks it checks the pump then the motor before filling. If the motor does not turn then the door lock light flashes.
    Sparkyp
    #181668
    Thanks for all the replies folks, I will approach in the morning full of confidence. 8)
    #181669
    forgot to update, went on Friday, new set of brushes, good as new. Thanks again folks. 🙂
