Whirlpool AWM8123
  • #9911
    SparkyP
    Hi Guys
    I have a Whirpool AWM8123 12 nc:-857081215100 that is doing strange things. The customer puts it onto a daily load 30 minute 30 degree wash and presses start. The door locks then pump action then fill action and wash action after a couple of minute the display shows 1 hour and 29 mins.
    Is it a module fault or a timer fault or even the connecting wire from the timer to the front module?
    Any advice or if anyone has had this problem b4 i start ordering expensive parts
    Cheers
    Sparkyp
    #136704
    Dave_Conway
    Re: Whirlpool AWM8123
    SparkyP wrote:The door locks then pump action then fill action and wash action after a couple of minute the display shows 1 hour and 29 mins.
    Then what happens SparkyP ? Stops dead in it’s tracks or aborts with an error code ?
    Motor brushes by any chance 😕
    #136705
    SparkyP
    Hi Dave
    No the machine just keeps going but does not do a spin cycle. I know that if there is no motor action on the whirlpool, the door open light comes on and then that is a motor fault.
    Sparkyp
    #136706
    Tubs
    Hi Sparkyp,
    I know you say display shows a time but do any of the spin speed leds flash?, this model uses them for error codes. Test routine on Sios Cd 💡 .
    I Only ever seem to have pressure stat chamber probs with this machine.
    Steve
    #136707
    SparkyP
    Hi Tubs
    The machine will not enter the diagnostic cycle. I have tried it a couple of times. I been servicing whirlpool for 10 years and this one is a new one on me. Any ideas?
    We have problems with the lead that connects the timer to the module. But that is a no display problem( Whirlpool do not supply these as a part have to get them from the returns) Any way this is usually F11
    This machine i am on now does not display any error code
    Hope this sheds any light on it
    Sparkyp
    #136708
    Tubs
    Hi Sparkyp,
    Just an 💡
    Have you checked heating element for low insulation?
    Had similar fault with Zanussi once. Done everything except spin 😕
    steve
