whirlpool AWM8143GB
  • #5198
    robbra
    Have FH on display after 5-15 mins of all washes.Have changed pressure switch to no avail and have cleared hose from top of tub to drain chamber. If I leave machine alone will it continue or just stop?
    Any suggestions would be appreciated.
    Many thanks.
    #109557
    Re: whirlpool AWM8143GB
    FH is a failure of one or more of the following
    water tap
    inlet valve
    flowmeter
    Pressostat
    check water tap is not an easy install one that punctures the pipe with a small hole…it can fur up
    inlet valve soleniods do seize during use
    flowmeter running slow practically un detectable to the eye but not to the pcb
    pressostat u seem to have covered
    finally the electronics try the others first
    ted
    #109558
    robbra
    Thanks Ted.
    Water tap is allowing plenty of water(not a quick fit type) in fact m/c fills up quickly ,about 2 mins,to a level above the bottom of the door and then runs for up to 15 mins.Everything is going well,then FH.
    Valves opening well.
    Flowmeter. Where is it,I didn’t see it.
    On refection it does seem to drain a little slowly.Could this whole problem be wrapped up with this.
    thanks.
    #109559
    hi
    I am at home now , will consult the tech data in the morning and reply soonest
    ted
