Whirlpool AWM8163 – F07 Error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool AWM8163 – F07 Error
  • #19319
    CBRMo
    Hi Guys, When I use the washing Machine, it will allow the water to intake for a few seconds then flashes up with the F07 Error message, I believe this is an Electrical Components Fault, Is it worth getting the machine repaired or is it time for a new one.
    Thanks.
    Mo
    #182618
    Re: Whirlpool AWM8163 – F07 Error
    Motor circuit problems – wiring and brushes are common failures on this range.
    Power off if investigating further.
    CBRMo
    Thanks for your reply Penguin, so would you suggest it is worth getting an engineer out to repair the machine, thing is I realy like this machine, best I have ever had, if its worth it I will call the guy that you recommended that fixed my dishwasher. He was excellent, and would not hesitate to call him again if the cost if feasible.
    #182620
    Not that old, so got to be worth a look, hasn’t it? I imagine your repairer will charge you for an hours work – brushes are cheap enough and are really a maintenance job rather than a fault.
    CBRMo
    Thanks Penguin, Just the answer we needed. I do love this site. 😀 😀
