Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWM8163 F11
- This topic has 10 replies, 4 voices, and was last updated 18 years ago by
iadom.
April 4, 2008 at 3:53 pm #35761
ModeratorJust spoken to this customer on the phone, machine showing F11. Fault code guide says comms error.
Is this likely to be poor connections or something more serious?
April 4, 2008 at 6:14 pm #247991robwash
ParticipantRe: Whirlpool AWM8163 F11
Hi, try connections on ribbon cable between timer and control module. If no joy…new timer/power board
April 4, 2008 at 6:45 pm #247992iadom
ModeratorRe: Whirlpool AWM8163 F11
Will do, :tup:
April 5, 2008 at 12:48 pm #247993iadom
Had a look at this today, an ominous burning smell when lid was removed. A spin of the drum and the death rattle from a knackered commutator was evident.
What is the chance of this just needing a motor given the error message was F11, could it have goosed the electronics.? 😥
April 5, 2008 at 2:31 pm #247994robwash
hard to say but its sounds like the F11 is from the lack of tacho action. if you have a motor, no harm in plugging one in. If its coming up with f11, it sounds like the timer is ok. cheers
April 5, 2008 at 4:13 pm #247995iadom
Don’t do a lot of Whirlpool so do not have the luxury of a spare motor. 😥
Decisions, decisions. 😕
April 5, 2008 at 6:27 pm #247996Grendal
Its worth checking the wiring where it clips under the tub had a few break there hth
April 6, 2008 at 11:00 am #247997admin
KeymasterRe: Whirlpool AWM8163 F11
Jim,
F11 means that you have problem with motor/choper module or no communication between main microcontroler and motor (choper) microcontroler.From yours words (smeling) something is damaged. Motor (which is DC) always take with him choper module but sometimes can survive… Main board allways survive in this case…
April 6, 2008 at 2:37 pm #247998iadom
Hi Adrian, motor has gone, a section out on the commutator, waiting for the customer to contact me now that she knows the cost of the motor alone. 😥
Would any damage on the chopper PCB be visible?
April 6, 2008 at 3:05 pm #247999admin
Not necessary :bounce: … and normally there is instead of one triacs one IGB-Transistor & one diode. I don’t know surely what is there because I didn’t meet one Whirl. with chopped motor… but I think that’s not different by all others (Aeg, Siemens, Miele, Gorenje…) :lesson: …
Like an encouragement :tup: : I have found just one IGBT blown and that from repairer fault… more often relays are going out… and motor microcontroller gives an signal who told that is in error…(has protection for overload current)… 😉April 12, 2008 at 3:14 pm #248000iadom
Just to update, a new motor cured the problem, both PCB’s fine. 😀
