Whirlpool AWO 3751/5 is singing to me (out of tune help!)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool AWO 3751/5 is singing to me (out of tune help!)
  • #32338
    compact
    I bought a Whirlpool AWO 3751/5 at auction as my servis died.
    It works absolutely fine, but when it is medium spinning, it is making a high pitch noise.
    Not a screeching, but more like a high note.
    Any ideas what this could be and how I could check/fix?
    Cheers
    #234728
    jackster
    Re: Whirlpool AWO 3751/5 is singing to me (out of tune help!
    This is a common fault on Whirlpool washers. The squeeling comes from the grease that was used in the manufacturing of the bearing i believe, it wasnt compatable. The only real cure is a bearing change to be honest 😥
    #234729
    If it’s an intermittent “Squee”…… it’s the seal in front of the bearings. Harmless, irritating, total demolition job to resolve with a gob of grease. If this fits your symptoms, turn the telly up and forget it.
    compact
    cheers for the replies
    Yep seems you guys have it spot on.
    Oh well it isn’t too bad, just annoying.
