not sure if iv recorded model number correctly AWO/D 45140 or awod a5147? i know off to a good start!, anyhow its a late whirlpool machine tested all functions fill, drain was spin will perform all for short time, but halts program with f05 on digital display did try search forums and come up with heater circuit or ntc? iv not checked heater or wiring
Usually the wiring harness lead under the tub to the NTC breaks away. Its got a stupid in-line connector that needs cutting away and then butt connector the leads instead.
