Whirlpool AWO/D 3080 – error code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool AWO/D 3080 – error code
Viewing 1 post (of 1 total)
  • #80614
    icamaster
    Hi there.
    I have a Whirlpool AWO/D 3080 with a problem.
    On any program it start to fill up with water (even in test mode) then it gives me an error (error F24 – water overflow detected according to this site, i don t know if it is correct).
    I checked the pressure swich and i think it works. If i give it water and the machine is turned off the water sais out, if i go on program it starts to fill with water. I blew (haha i know) into the pressure swich hose and it is ok, i can hear and feel the air getting out.
    In test program it gets stuck in first program.
    What can i do?
    Also, heating element has 26ohm and the NTC 18kohm when turned off. Are these values ok?
    The error code and test i took from here http://www.ukwhitegoods.co.uk/help/faul … codes.html
    Thank you. Sorry for my english btw.
