whirlpool AWO/D 4505 wont spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum whirlpool AWO/D 4505 wont spin
  • #47407
    telemek
    This machine washes fine but when in the spin cycle it distributes the load then starts a slow spin then stops then repeats and stops until end of cycle.
    Tried it with no load on spin only cycle and it will go to a fast spin for a few seconds then stop and repeat but the whole cycle is very short (about 1 minute).
    Any help with this would be greatly appreciated.
    #293363
    Payney
    Re: whirlpool AWO/D 4505 wont spin
    This sounds like there is a problem with the tacho on the motor. Could need replacing. If you are looking yourself make sure you are safe and always unplug while checking.
    Hope this helps.
    #293364
    telemek
    Hi Payney
    Thanks for your reply, I will check tacho coil & connections.
    Graham
