Whirlpool AWO/D 4705 dead.
  • #54782
    12nc. 859233315000.
    Customer says it was working perfectly. did one wash this morning fine, tried to set a second wash and machine is totally dead, no lights, no door locking nothing.
    Live & neutral up to main PCB, motor brushes OK, door lock fine but there are no signs of life.
    A visual check of the main PCB reveals no obvious signs of component or track damage.
    Do the PCB’s on these have any history of this kind of fault?
    Re: Whirlpool AWO/D 4705 dead.
    Have you checked the 22 ohm fusible ( I think) resistor on the board?
    Do a search “22 + wirewound” should bring it up. If not, could be brushes apparently.
    Mike.
    #320953
    New resistor did the trick. 8)
