Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWO/D 5706 dead
- This topic has 14 replies, 5 voices, and was last updated 14 years, 8 months ago by
iadom.
August 4, 2011 at 3:37 pm #64324
Moderator12 nc. 8592 474 15000.
Power into main PCB but no lights at all and machine will not start.
A visual of the PCB shows no signs of obvious damage. Is this a known problem with this machine.
Also does anyone know the part number/price of the PCB?
TIA.
August 4, 2011 at 4:24 pm #356724BobHope
ParticipantRe: Whirlpool AWO/D 5706 dead
control pcb part no. 481221470046 programmed
481228210207 un-programmed. have you checked the motor as this can give you a dead appliance.Bob.
ps if you want the service manual pm me an email address. 🙂
August 4, 2011 at 4:53 pm #356725iadom
ModeratorRe: Whirlpool AWO/D 5706 dead
Motor brushes etc are fine, first thing I went for TBH.
Would a motor fault cause no display lights at all though, I usually find they will light up but then do nothing else if the brushes are worn.:?
I do have a copy of the last but one SIOS disc on my laptop, sadly despite johnmacs best efforts it will not run on this (desktop) PC.
I was in a rush when I posted earlier so didn’t bother firing up my lappy. 😳
Thanks for the part numbers.
August 4, 2011 at 11:27 pm #356726reaper
Is this one of the models where the 22ohm resistor on the programme switch goes o/c.Theres info in the simple pcb repair section.
August 5, 2011 at 12:49 am #356727leavemetogetonwithit
Had one with an o/c htr element gave same symptoms.
Mike.August 5, 2011 at 8:28 am #356728iadom
Will check those out. 🙂
August 6, 2011 at 11:33 am #356729iadom
reaper wrote:Is this one of the models where the 22ohm resistor on the programme switch goes o/c.Theres info in the simple pcb repair section.
Excellent call reaper, went back today and that very resistor is O/C. :tup:Jim.
August 6, 2011 at 12:43 pm #356730iadom
Can anyone confirm that THIS will be suitable.
The one on the board has red, red, black space then gold rings.
August 6, 2011 at 1:36 pm #356731leavemetogetonwithit
See Martin114’s post here The one you’ve chosen might be just a bit big, might make it a squeeze for space. Edit: Just realised it is probably a protection device too, so it would be like fitting a higher value fuse 😯 .
I can post you a couple 1st class Monday am if you email me your address.
Mike.August 6, 2011 at 1:50 pm #356732iadom
Thanks Mike, reading that post reveals that I was involved in that thread. Its a possibility that I may have ordered some of those at the time, now just need to find the little blighters. 😳
August 6, 2011 at 2:23 pm #356733iadom
Sorted, I ordered five at the time, just found the other four. 8)
August 6, 2011 at 2:30 pm #356734leavemetogetonwithit
The time you spent hunting them down, you could have fitted in another WMA bearing + spider job 😆 .
Mike.August 9, 2011 at 10:36 am #356735Martin
iadom wrote:Sorted, I ordered five at the time, just found the other four. 8)
I’ve just received 5 of these resistors from RS (152-347). Now, where exactly on the board in question do I stuff it? Do please keep you reply clean, play fair and in as few words as possible to enable this old duffer the chance to grab this hi tech opportunity for all its worth. A piccy of the board would help too! 😀
August 9, 2011 at 5:32 pm #356736iadom
From memory 😳
I think the resistor is numbered R020 on the board.
I just checked them all until I found the O/C one.
August 9, 2011 at 8:01 pm #356737Martin
Ta muchly!
