Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Whirlpool AWO/D049 – F12/heater circuit issue
- This topic has 9 replies, 2 voices, and was last updated 8 years, 4 months ago by
cynic-al.
November 28, 2017 at 7:14 am #92724
cynic-al
ParticipantHi all, I’m getting this error code after replacing the main circuit board for a door lock sensor issue which is now resolved – (it’s a used board though, so I guess it may be the problem itself?).
Here’s what the guide says I should do
1. Check water heating element for continuity
2. Check water heater for earth leakage
3. check heater resistance
4. Check all wiring and connectors to the heater and from there to the main controller
5. Check main control unitHere’s what I’ve done
1. I don’t know what this means
2. measuring resistance from the earth to the live and neutral gives megaohms.
3. it measures 27ohms which seems right for 2kW
4. they seem OK
5. Well I have no idea how to do that!I’ve also seen elsewhere to check the motor brushes (it’s 9 years old) and also relays on the main circuit board.
Any ideas, particularly help on 1 and 5 and if I have done 2 correctly? Cheers…
November 28, 2017 at 7:50 am #451984electrofix
ModeratorRe: Whirlpool AWO/D049 – F12/heater circuit issue
1 and 3 are the same so you have done that
2 gives megohms but how many and to be accurate it would need to be checked with a 500v insulation meter. to apply logic before the old board failed it was not a problem so chances are low its faulty now
the heater is controlled by a relay on the main pcb. its not unusual for the soldered connection on these relays to fail. find the relay and have a close look at the solder joints
[quote=
4. they seem OK
5. Well I have no idea how to do that!Any ideas, particularly help on 1 and 5 and if I have done 2 correctly? Cheers…
November 28, 2017 at 6:34 pm #451985cynic-al
ParticipantRe: Whirlpool AWO/D049 – F12/heater circuit issue
Thanks. All solder joins look great.
Re measuring the earth with my £12 maplin multimeter gives 100k ohm which was rising slowly but I got bored.
November 28, 2017 at 8:34 pm #451986electrofix
disconnect wires from heater and check to earth
at 100k to earth is far too low
November 29, 2017 at 6:45 am #451987cynic-al
Ta – infinite resistance measured.
Now for the motor brushes!
November 29, 2017 at 6:56 am #451988electrofix
take old brushes off
if they have failed they will be very short. new brushes stick out about an inch. anything over 1/4 inch should work ok but would need changing if there are no other faultsDave
November 29, 2017 at 8:49 pm #451989cynic-al
Thanks.
The brushes looked great, easily 10mm of wear left in them, and zero ish resistance.
Might get a man in now!…or look at a replacement
December 1, 2017 at 8:53 am #451990cynic-al
Oddly it doesn’t go into test mode when you press reset 4 times on switching to drain.
So I tried a run and it then gives me a F21 error.
I’ve ordered another board…
December 2, 2017 at 4:33 pm #451991cynic-al
Well the other board gives the same errors.
Time to call a man…
December 8, 2017 at 4:31 am #451992cynic-al
Man said drum bent…and he’s right. New WM time!
