Re: Whirlpool AWO D049 problem
Right. Everybody finished?
All posters are advised, once again, to read and understand the FORUM RULES as a starting point for what the professionals will and won’t do to help you and what the amatuers are allowed to tell you.
The information provided by Higher-Water-Level, whilst possibly technically correct, was described completely incorrectly. The pressure switch is located under the timer/module unit. It has a connecting hose to the air bell on the front of the outer tub. The only way to investigate this problem correctly is to remove the front panel from the machine, with the power disconnected of course.
H-W-L – I would suggest that you contact spares@ukwhitegoods.co.uk with your spares requirement. I can find no reference to the model number you have posted. Siltal do not sell under their own name in the UK, so a check for the actual badge will help you..
Penguin45,
Moderator.
