Whirlpool AWO/D4605 Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWO/D4605 This topic has 4 replies, 3 voices, and was last updated 15 years, 3 months ago by geoff1. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts December 13, 2010 at 10:36 am #59537 geoff1Participant Hope I have the model correct. The problem I have is that it is intermistant on spin. Fitted pump as it was buzzing without turning. Job done so I thought. Its back to day but the pump is running ok and the cycle goes through to the end but there is no motor action of spin. Does anyone have a manual to help on my return tomorrow more so to help with test programme?? Many thanks Geoff December 13, 2010 at 12:55 pm #338582 MartinParticipant Re: Whirlpool AWO/D4605 geoff1 wrote:Its back to day but the pump is running ok and the cycle goes through to the end but there is no motor action of spin. So, I have to ask, have you checked the motor and the wiring harness to it? December 13, 2010 at 1:17 pm #338583 Micky 32Participant Check that the pressure switch chamber isn’t blocked. Come actross a few that were that gave an intermittent spin. Also have come across a broken wire at the motor plug. December 13, 2010 at 5:12 pm #338584 geoff1Participant Re: Whirlpool AWO/D4605 Hi Will recheck motor wiring as last time I was there I could find no problems with it. Pressure chamber nice and clean As to the fault it will spin one day then the next it will not. Geoff December 14, 2010 at 7:03 pm #338585 geoff1Participant Re: Whirlpool AWO/D4605 Education was the answer. 1 small quilt and 1 sheet Customer in a panic as this load was not spinning 😯 OOB 😆 Geoff Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
