Whirlpool – AWO/D4605
  • #63968
    gadgetdad
    Hi guys,
    visited the above washer on thursday – had flashing start light and solid service light, and was not letting in water. Checked inlet and was open circuit. Returned friday with new inlet valve popped it on and we now have – flashing pause light/solid service light, water coming in but it fills half way up the door bowl, pauses, the service light goes off briefly then comes back on then it pumps out but the inlet is still letting in !!
    Have replaced pressure switch tube, checked element, have manually checked pressure switch by blowing/sucking whilst machine is filling and this appears to be working.
    Hoping its not the module as the customer cant afford it !!
    Any advice please.
    gadge
    #355684
    Re: Whirlpool – AWO/D4605
    it sound like another fault code
    there is a list of fault codes for this machine but no info on how to read them
    did you count flashes to see if a number coresponds to the fault codes ?
    gadgetdad
    I did count them but it not a count just a continuous flash – no pauses !!
    Wheres the list of codes please.
    gadge
    #355686
    list of fault codes it the stickies at top of this forum only lists them as F1 F2 etc
    Let me know how you get on
