Whirlpool awo/d5556
  • #62155
    peeler40
    Repairing a whilpool washing machine which would not fill .
    On inspection the machine had been moved and some how ripped
    the three wires from the water feed valve .the problem i
    have fixing this is all the wires are the same colour (blue)
    The three wires go from the program board to the water inlet
    valve are seperate from the main wiring harness ,would any one
    know if these are availible ? .Any advice please .
    #348955
    Re: Whirlpool awo/d5556
    You could replace the valve with a more conventional type (e.g. Connect’s VAL98115 10.5mm bore, allegedly fits Whp) and use crimp connectors. Just need to experiment a bit with volt meter, to find which wire does what, when. Or just pull off the circuit board from the existing valve terminals and you’ll have bare terminals sticking up. Need to lengthen wires and make sure it all goes back safely of course. ( I say that not for your benefit, I’m sure you’re perfectly competent, but in case someone says I’m a cowboy for suggesting such a thing :rolls: )
    Mike.
    #348956
    peeler40
    Thanks leavemetogetonwithit looking how the valves are wired up
    seems best , if i can open them up without wrecking them .
    #348957
    peeler40 wrote:if i can open them up without wrecking them .
    I’m sure you can. I did it on a Bosch which had same sort of valve at similarly daft price!
    Mike.
