whirlpool awo/d5706/s
  • #77153
    suedehead1
    hi, the above washing machine is showing F26 fault which means
    the pump triac is faulty.
    I removed the main module and the pump triac has blown.
    The obvious assumption would be the pump must have blown the triac
    but it looks ok and tested ok.
    I am reluctant to put on a new module in case it goes the same way,
    I would change the pump before trying it but I am still unsure that
    there isnt another fault with the machine.
    #401191
    Re: whirlpool awo/d5706/s
    Well it certainly will need both pump and PCB replacing to be sure. Perhaps though water got onto the pump terminals causing the triac to blow?
