whirlpool awo3671
  • #31871
    comptonappliances
    this machine will not start i.e door wont lock
    door lock is ok changed it to see but when you move the cam on the timer manually the door will then lock but then when you select a program again and start same fault occurs / no flashing lights or error codes any ideas welcome thanks
    #232774
    Re: whirlpool awo3671
    Motor out of circuit can do this.
