WHIRLPOOL AWOE 8748
Viewing 1 post (of 1 total)
  • #56101
    richardable
    this is a w/m about 14months old. been twice now. on arrival she has loaded machine and selected the wash. no lights, door locked, can’t open it. did some tests, 240v, live and neutral. water on. did some more poking about and the panel lights up. machine then carrys on as normal. back again today. same scene. after 20-25mins lights up showng F13. turn through programs to off and then goes dead. open door manually. all looks ok. select program all is well. so, is it a board fault or an interlock fault. F13 is dispenser cct fault on the w/pool sticky…saw a report that there is a22m/amp wire wound fuse on the board which if faulty gave similar conditions on another w/pool model..
    iadom you had the fix on this one earlier this year…any info.
    thanks
    richard
