Whirlpool AWOE 9120
  • #94792
    Jarek Piechota
    Hi can anyone help ? My washing machine has stopped mid cycle without finishing program and draining. No power indication or any led’s on the display does not work at all. Traced wires and there is 240v supply to both programmer and control PCB . Thinking it could have been controller PCB or the programmer i have bought both brand new, fitted them and the problem is still the same, power supply is there but nothing is happening no lights or LED’s . The only thing that is happening when turning on the programmer selector knob it turns the power supply to all of the machine but still all buttons LED’s are dead and nothing is happening. Any suggestions please on what the issue could be as i have run out of any more ideas . Thanks Jarek
    #458355
    All I can suggest that would make sense to me at least, is there’s a broken wire or faulty plug to the display module. Finding it though might not be so easy.
    Jarek Piechota
    Thank you sounds like it might be the issue. I will check all wiring and plugs for continuity.
