Whirlpool AWOE8558 washer. 8592 977 1500L.
18 month old machine. The display shows just a few lines whatever program is selected. Tried all connections to the main PCB and the display plug, all seem OK. The door intermittently stays locked after a cycle as well. 😕
I can’t find any parts on Connect or Qualtex (I suppose it’s too new). The interlock may have a fault and probably not expensive; but the display is separate to the main PCB…. not quite sure which is at fault. Anyone had a similar problem? Any help would be appreciated.
Thanks,
Steve.
