Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWOE8758 – F13 Error code
- This topic has 7 replies, 4 voices, and was last updated 15 years, 8 months ago by
trotter.
July 27, 2010 at 7:58 am #56115
trotter
ParticipantF13 it seems is a dispenser circuit error BUT will I need the whole kit? listed on connect as WPL480111100333
Customer says machine is only around 15 months old….is this a common fault guys?
Ta very much in eager anticipation 😀
August 30, 2010 at 12:09 pm #326267Martin
ParticipantRe: Whirlpool AWOE8758 – F13 Error code
I have the same problem reported by a customer today. Booked in for tomorrow so here’s hoping someone meanwhile can help – please? 🙂
August 31, 2010 at 8:21 am #326268mbdas
Ive had same fault a few months ago turned out to be door interlock 🙂
hope that helps
mark 🙂August 31, 2010 at 9:41 am #326269trotter
My customer decided to re[place machine rather than risk possible pcb fault 😥
Thanks for the reply though …..good for further calls
August 31, 2010 at 11:08 am #326270Martin
Took a gander at this beast this morning. The door is locked, can’t open it even with the power off! Also the display/Led’s are dead, no sign of life within. Is the door interlock a solenoid release job as there doesn’t appear to be a door latch? 😕 The m/c is just 20 days out of warranty too. 🙁
Is it a scrapper? Or where best should I thump it? I’ve tried the crystal ball technique but it’s too cloudy to see anything! 😕
August 31, 2010 at 3:58 pm #326271mbdas
No I think it was just like a normal Bi metal interlock i Thumped the door switch with the end of my screw driver 😉 and then could open the door and then the machine came to life 😕 but the switch was a special order and was about £50 trade 🙁
September 1, 2010 at 7:15 am #326272Martin
Tnks for that, scrapper it is then……
September 1, 2010 at 11:16 am #326273thankevans
definatley door interlock we have done quite a few recentley machine will go dead, give it a thump door will open and it will power back up. replace door interlock.
